felixmartin1
Nov 11, 2013Aspirant
EMPTY in Frontview...
Most of the fields appear EMPTY on Frontview. My files are still accessible, but I can manage the ReadyNAS PRO
It is spotty, I can access sometimes, most of the time not.
I have had messages of impending failure on one drive and have ordered a replacement.
Is this going to go away after I replace the drive?
- StephenBGuru - Experienced UserWhat browser are you using?
- felixmartin1Aspirantsafari, has worked for years...
switching to chrome - mdgm-ntgrNETGEAR Employee RetiredWhat version of RAIDiator?
- felixmartin1Aspirant4.2.24
- mdgm-ntgrNETGEAR Employee RetiredOdd. Safari works well for me. Though if the NAS is under heavy load other browsers can be better.
- SandsharkSenseiThat can be caused by an Apache configuration problem. An OS re-load will often fix it. It shouldn't cause you to lose anything, but a backup is always a good idea. Since you should also be backing up before replacing the drive, now it the perfect time to give it a shot. And if that doesn't work, then the full factory default is the next thing to try. That, of course, does erase the drives.
