GIFF's avatar
GIFF
Encryption, (FDE or equivalent)
I would like to request FDE or the equivalent in a RAID environment. My budget does not allow for an impenetrable computer room and my entire life, or at least part of it, is in one spot, on your device. AES would be best. I recently made the move to IBM from Dell due to the improved hardware level encryption and capacity options. Software or hardware encryption works. Maybe you can utilize existing drives that already have FDE.
Within reason you can not put a price on security.
Lastly, did I mention stable encryption.
RG
  • Maybe not possible due to ReadyNAS CPU restrictions, but add my vote for encryption "a la Truecrypt" :)
  • +1 for USB drive encryption for frontview backups. If one of my backup drives is lost/stolen when taken off site all my data is exposed.
  • I would also be interested in encryption.
    I am contemplating setting up a computer system for a small business (~3 workstations accessing a shared database via LAN). A third-party closed application would store confidentila client information on the LAN. For this particular application the standard security involves nothing more than the physical security of the site. I am considering using a ReadyNAS to store the database (for reliability and redundant storage).
    I would like the database to be protected against opportunistic theft of the NAS or disks. (The data is not sufficiently valuable that anyone would steal the disks or hack the LAN to get the data. It is more likely that someone would opportunistically break into the business and steal the NAS because it looks saleable.) I would like the encryption to be transparent to the application program. (Something like a boot-time password on the NAS would be adequate.) I would also need to be able to make encrypted off-site backups. The strength of encryption should be adequate to defeat your average neighbourhood hacker - not government agencies or crypto-professionals.
  • I would like encryption as well. Encryption of the disks in the device is nice. Encryption of USB attached drives used for backup is even nicer.
    To rephrase, if I attach a USB drive to the front and press the backup button, the data is optionally encrypted on the USB drive. This allows me to store the backup drive remotely without worrying about the contents.
    Obtaining the key + SW recovery tool would be out of band (for instance through FrontView).
  • When requesting encryption, you might want to talk more about your needs.
    My assumption when someone says Full Disk Encryption, is that they want it such that the data is unreadable if the drives or the ReadyNAS gets stolen. FDE's not a solution if you want end to end data encryption. With a FDE solution, the data's going to be in the clear going from the NAS to the client computers (so if someone has a sniffer out, it's possible to get your data).
  • If encryption support comes, then I would only want it to do work on certain shares/folders and not the whole volume.
ProSupport for Business
