richbeale
Dec 07, 2019Aspirant
existing readynas Duo drive in same machine
Hi Following my previous post earlier. I have 2 drives that i removed from my NAS DUO, both were working I am pretty sure, had no issues. removed them, used another drive, and now want to...
Dec 07, 2019Guru - Experienced User
Let's stay with your original thread, instead of starting a new one with each followup. I will lock this thread.
I replied to your original post here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Removed-drives-reinstalled-and-keeps-wanting-to-wipe-the-drives/m-p/1833678#M38981
richbeale wrote:
One existing drive I have tried, wouldnt access the drive, shows up on my network, but am unable to access it says the 'volume scan failed to run properly' tried reinstalling the OS NOT A FACTORY RESET and still nothing. has this data gone?
I don't know what happened there, though I still suggest following the path I outlined in my other post. It is possible that the data is gone, but it is also possible the R-linux for Windows will find it and allow you to offload it.
richbeale wrote:
I still have the other drive with out it being touched, can I put that in and should be ok, will it try and AUTO format the drive? As I dont want to loose the photos etc on the drive.
If you insert the drive with the NAS powered down, it should only auto-format if it sees a blank (unpartitioned) disk.
richbeale wrote:
Thought having two drives mirrored id not have this problem!
One thing to remember is that while RAID redundancy is a good thing, it isn't enough to keep your data safe. There are lots of ways that RAID can fail, so you still do need to have a backup of your data on another device.
