jonl0711's avatar
jonl0711
Expanding the EDA500
I had a EDA500 attached to a RNAS314.  The 314 is set for Raid5 with 4 x 3TB drives.
The Expansion unit has 2 x3TB drives in a separate volume RAID1.
I would like to either expand this volume by adding 2x 3TB drives or is it better to create a new volume?
Also I noticed that by moving the mouse over the units they are reporting the wrong information (volume capacity, etc.)
Is there a fix for this?
Thanks
  • StephenB's avatar
    Can you post a screen shot of this?  It'd be good to clarify it before you try to expand anything.
  • It depends of what you want.
    if you want another RAID1 3Tb why not?
    If you want 4x3Tb RAID 5 why not?
    1st solution is quick and and easy but you loose 1HDD
    2nd pretty long and you have to add parity and wait for building and doing things properly!
    TAKE YOUR TIME IS THE KEY!!
ProSupport for Business
