mgrzywacz
Oct 19, 2012Aspirant
External Seagate Backup Plus 3TB HDD shows ""No Filesystem"
I have a ReadyNAS Duo v1 and an external Seagate Backup Plus 3TB hard drive attached to the front USB port. This is the product page for the Seagate drive: http://www.seagate.com/external-hard-dr ....
HERBIEO
Are you using it for backup ? if so you could connect it to your computer enable sharing on it and then set up a backup job in frontview.
