nas102
Apr 25, 2014Aspirant
extremly hot temperature and slow fan RN 10200
hi, i live in country with hot tropical climate, seldom use air conditioner. observe hot temperature 70C-80C consistently on my RN 10200. question: 1. is there any way to increase speed of f...
dishmagic66
Apr 26, 2014Guide
For the brave ones who are not afraid to use SSH:
You can read http://www.readynas.com/forum/viewtopic.php?f=7&t=71587
With this done, my RN104 with 4 discs runs pretty cool. My cpu temp stays around 50 degrees and my discs stay around 40 degrees.
idling the fanspeed is around 900 - 1000 rpm. (room temperatuur around 22 - 23 degrees)
In your tropical climate it will run most likely around 1500 rpm.
You can tweak the low and high temps a bit in the script, to find a compromise between temperature and fan-noise.
