Dewdman42
Jul 16, 2025Virtuoso
Factory Reset and some questions
Continuation from other thread about my bad disk(s)... Now that I have factory reset it, it's a bit depressing to realize I lost all kinds of customizations I had made to ReadyNASOS over the cour...
Jul 19, 2025Guru - Experienced User
Dewdman42 wrote:I would be curious if you try to install it what happens.
It does install on my RN526x running 6.10.9 - and shows up on the apps page.
apt_history shows this:
Start-Date: 2025-07-19 08:13:00
Commandline: apt-get -yq install --reinstall --allow-downgrades -o APT::Status-Fd=5 /tmp/nzbget-rn_17.1-6_amd64.deb
Install: p7zip:amd64 (9.20.1~dfsg.1-4.1+deb8u3, automatic), unrar-free:amd64 (1:0.0.1+cvs20140707-1, automatic), nzbget-rn:amd64 (17.1-6), libjs-twitter-bootstrap:amd64 (2.0.2+dfsg-5, automatic), libjs-jquery:amd64 (1.7.2+dfsg-3.2+deb8u7, automatic), libjs-raphael:amd64 (2.1.0-1, automatic), libjs-elycharts:amd64 (2.1.5+ds-2, automatic)
End-Date: 2025-07-19 08:13:13
Note I have made the changes to apt, which might be a factor here.
