Dewdman42
Jul 16, 2025Virtuoso
Factory Reset and some questions
Continuation from other thread about my bad disk(s)... Now that I have factory reset it, it's a bit depressing to realize I lost all kinds of customizations I had made to ReadyNASOS over the cour...
Jul 20, 2025Guru - Experienced User
Dewdman42 wrote:not sure what to make of it, something about key expired?
The debian folks aren't renewing the certs, and they are expiring over time. The overrides in apt.conf are intended to them to be installed anyway (which is why they are warnings).
Dewdman42
Jul 20, 2025Virtuoso
Do you know did netgear take down the so called "dev" repo? that's where their version of build-essential was I believe, I need netgear's version of lib6c-dev in particular. It seems this repo is no longer up anywhere...the "dev" section anyway... Maybe I am missing something. I am getting and ERROR related to netgear's repo in general, so not sure if that is relevant or not..but well..might be beating my head against a wall if netgear took away the actual dev packages such as libc6-dev and build-essential.
