batook
Mar 28, 2020Aspirant
Factory Reset Not Working To Setup New Drive
My end goal is to get 2 Western Digital Caviar Green 2TB WD20EARS drives running in this ReadyNAS Pro 2 as separate independent volumes (JBOD). I've read on here that could be possible by first doing...
- Apr 01, 2020
Success! I was able to extract the firmware, mount the flash memory, and overwrite the files to perform a manual firmware update. I made sure to check the md5sums of all the files before I rebooted to make sure everything was ok.
Extracting the firmware proved a little challenging, because it's all wrapped in a nondescript package. I found an article here which explained how to use binwalk to get the position of the files, and then using dd to extract a tarball using that position information. Since I don't have a linux box running right now and couldn't run binwalk on the NAS busybox, I just downloaded the 4.2.30 firmware version the author of the article used and copied the same dd command to extract the tarball for that specific firmware version.
Rebooting allowed RAIDar to detect the 4.2.30 firmware (it was never able to display 4.2.26 previously because of the file corruption), and the factory default with a single drive connected completed successfully for the first time ever. I was then able to access the Frontview web GUI and upgrade from there to the latest 4.2.31.
Marc_V
Mar 29, 2020NETGEAR Employee Retired
Welcome to the Community!
Have you tried using an older version of RAIDar? The latest version is not applying the settings you set when initializing the NAS.
Here is a link for an older version of NAS. Kindly try using ver 4.3.8
HTH
Regards
batook
Mar 30, 2020Aspirant
Thanks Marc_V. I tried running RAIDar 4.3.8 but I'm getting the same problem. I can ping the IP and even access telnet when I load the factory defaults boot option and it's in the "testing drives" phase and while the "Setup" option is available. Once it starts creating the volume, it says it completes 100% and then closes out from RAIDar. The power light stays off for about an hour, and then turns back on, but RAIDar can't scan it at this time, and I can only ping the device then, no telnet. I left it overnight to make sure it wasn't still working, but still nothing. Powering it off and back on doesn't change anything, there is no telnet and no ability for RAIDar to find it. I put the drive into my windows box and found that it created 4GB (OS?) partition, a 512MB (swap?) partition, and the remaining 1858GB data partition. I haven't booted into linux to see if it actually wrote any data to the 4GB partition. Is there maybe something wrong with the Raidiator 4.2.26 firmware version that could be fixed by upgrading to the latest version?
- mdgmMar 30, 2020Virtuoso
This certainly suggests that corrupt firmware on the internal flash is one possibility. There are others.
- batookMar 30, 2020Aspirant
Trying to update the firmware via USB recovery hasn't worked for me either though, it just hangs and never seems to read from the flash drive. Is there anything else I could try to get this to work?
- mdgmMar 31, 2020VirtuosoIt’s straightforward to check the internal flash using telnet. You have already advised above in an earlier post that you were able to telnet into the device.
If you mount the internal flash you can check that the md5sum checksums match those in the md5 file. I expect you may find that one of the files is corrupt.
