thelinuxfr
Oct 21, 2011Guide
Fail2ban in FrontView
Hi,
fail2ban installed by default and manageable via the FrontView services with SSH, FTP, HTTP ...
Thx
Thx
- timvdAspirant+1 from me
- crumbAspiranthello
that's right fail2ban is really appreciate. I have few peoples all over the worlds who tried to connect to my Readynas ultra.
i can see then when i do a :
cat /var/log/auth.log | grep Failed
so, i tried to make a :
sudo apt-get install fail2ban
but i always have a problem when it tried to configure itself after the installation ... agreed to the log, there is a problem with python (python2.4 is required)
i have python 2.7 i installed in frontview from : http://readynasxtras.com/readynas-x86-add-ons/python-26-x86
so i tried to :
apt-get remove --purge fail2ban
apt-get autoremove
but same problem again and again.
Finnaly it worked when i install fail2ban with the sources :
- Downladed http://sourceforge.net/projects/fail2ban/?source=dlp
- untar and cp in the new directory
- python setup.py install
and then, it worked !!!
so after that i had to configure fail2ban :
edit /etc/fail2ban/jail.local (which is a copy of the original jail.conf to preserve the original conf)
i turned
[ssh-iptables]
enabled = true
port = ssh,22
logpath = /var/log/auth.log
[proftpd-iptables]
enabled = true
port = ftp,sftp,"my specific port"
logpath = /var/log/proftpd.log
then made a
fail2ban-client reload
fail2ban-client status
which respond a :Status
|- Number of jail: 2
`- Jail list: proftpd-iptables, ssh-iptables
then i tried to connect to my readynas with a 3G smartphone, and failed 6 times to the password
>> my 3G IP was banned, and i automaticly received a mail which tell me which IP was BAN.
/var/log/fail2ban.log give me that :2013-01-05 18:04:46,453 fail2ban.actions: WARNING [ssh-iptables] Ban 37.8.177.xx
2013-01-05 18:14:46,828 fail2ban.actions: WARNING [ssh-iptables] Unban 37.8.177.xx
