ranchracer
Jan 08, 2017Aspirant
Failed HGST Nextar on RN214
I've been running a 214 with dual 4TB HGST Nextar NAS drives for a couple of months now. We just had a power outage and when the system came back up it was showing a degraded data status and only see...
ranchracer
Jan 09, 2017Aspirant
Yes I realize that disk 2 is bad and it's not a good idea to run non-redundant for any extended period of time. My question is, how do I reformat disk 2 prior to reinsterting and hoping it successfully re-syncs with the array? I have always only run 2 disks, but plan on adding two more, as well as a completely separate RN214 with its own disks that I will use only as a backup array to my primary.
So my question is, how do I reformat the failed drive to see if I can get it back into the array? GUID partition I assume, but what about the file system? Is it MsDOS (FAT), ExFAT? I have no idea how these drives come formated from HGTS. They are specifically designed for NAS RAID.
JennC
Jan 09, 2017NETGEAR Employee Retired
Hello ranchracer,
When you format the disk using a computer and you insert it to the NAS, the NAS will detect that it has volume. You need to let the NAS format it instead which means factory reset. So, the best way is since you still have access the to the files while disk 1 alone is inserted, have full backup of the files first. Then factory reset with the 2 disks inserted. This will format the 2 disks and will let you create a new volume.
- ranchracerJan 09, 2017Aspirant
Ok so it sounds like a factory reset is my best option. I'll back up my data and get ready to do this. Rigth now my problem is that the ReadyNAS won't even recognize disk 2 so I'll need to put some kind of format on it anyway just for the RN214 to actually see it.
- SandsharkJan 09, 2017Sensei
You could try deleting the partitions on the drive and re-inserting it, but I can't help you do that on a Mac. But it sounds like the drive is toast and that's not going to bear fruit.
