MMarbleSLHA
Oct 25, 2017Aspirant
Failed to retrieve directory listing
I'm having some trouble with internal-only FTP. Filezilla authenticates, but I'm unable to browse to the folder. I get the following (minus the hashtags). Status: Resolving address of ###.###.#...
Oct 25, 2017Guru - Experienced User
Is users a share on the NAS? Did you navigate there by clicking on the foldername in the root share?
If so, is the share set to give your user credentials access? Check the FTP tab in Network Access (share settings), and also the File Access tab. Perhaps enable "everyone" access intially, just for testing.
MMarbleSLHA
Thanks for the reply. The share and folder name is IT. I vaguely remember users being a system folder for Unix.
I did try setting the permissions to everyone, but got the same result.
