Rob_Robertson's avatar
Apr 24, 2019
Failed Upgrade from 6.9.5 to 6.10.0 RN516
I upgrade FW from 6.9.5 to 6.10.0 via the OS and auto update. On restart the system reaches 99% and hangs When I toggle the power switch the lcd rotates between booting and MySQL.service
  • OK, so after many attempts at restarting the NAS, all of them resulting in it being stuck generally on booting the MySQL module I decided to recover the NAS OS. I downloaded the attached file and followed it to the Recover NAS OS prompts to reinstall the update. Mine is running fine now.
    • JohnCM_S's avatar
      JohnCM_S
      NETGEAR Employee Retired
      Hi antileech,
      Welcome to the Community!
      Have you tried doing the OS reinstall? If yes, what was the result?
      Here is the link if you need the steps on how to access the boot menu and do the OS reinstall.
      • antileech's avatar
        antileech
        OS reinstall worked for me. Had to redo all my sharing and user permissions though. Haven't run into any other problems since.
        Thnx
ProSupport for Business
