Capell
Jun 06, 2018Aspirant
Failure of Netgear Technical Support
I am having problems connecting a NAS424 to an Eaton UPS 5P. I have raised this with Netgear support, and I have a running support case: 30039834. It's reached level 3. But now I can't reply to my ca...
Marc_V
Jun 06, 2018NETGEAR Employee Retired
Hi Capell
Welcome to the Community!
There has been a downtime on Support lines and pages as well as logins. This is due to the new Support tools that NETGEAR is implementing.
Your old case 30039834 has been assigned a new case number 00296105. You can contact Support using +44-344-453-8000 and going to presales instead. Press 2 for non tech concern then press 3 for new product and 3 again for prosafe. then provide your case number to be pulled up.
Im sure your case is being worked on and Support is following up on your case.
Regading your profile, you should be able to see the new case when logging in to my.netgear.com, are you saying the case is not showing?
Regards
Capell
Thanks for your reply, and the information about the new case number. I do appreciate finally maikng contact with someone from support!
Part of the problem is that I have changed my e-mail address. I seemingly have two accounts, with different login names (i.e. the e-mail addresses) and different passwords. It was part of the current case 30039834 that this would be resolved. I thought it had been resolved.
The old account name sees that I have an NAS424, but I have no outstanding support cases.
The new account sees no products, no support cases.
So: both support cases 30039834 and 00296105 are missing.
