Capell
Jun 06, 2018Aspirant
Failure of Netgear Technical Support
I am having problems connecting a NAS424 to an Eaton UPS 5P. I have raised this with Netgear support, and I have a running support case: 30039834. It's reached level 3. But now I can't reply to my ca...
Capell
Thanks for your reply, and the information about the new case number. I do appreciate finally maikng contact with someone from support!
Part of the problem is that I have changed my e-mail address. I seemingly have two accounts, with different login names (i.e. the e-mail addresses) and different passwords. It was part of the current case 30039834 that this would be resolved. I thought it had been resolved.
The old account name sees that I have an NAS424, but I have no outstanding support cases.
The new account sees no products, no support cases.
So: both support cases 30039834 and 00296105 are missing.
mdgm-ntgr
Jun 06, 2018NETGEAR Employee Retired
The new case number 00296105 is the one to use going forward. It's the same case just a new number for it.
The case is attached to the same email you use for the community.
If you can PM us the details of the old account and the new account we can pass on the account merge request. Do you use just this account on the community or the other account as well?
You can also email us the logs from your system if you like (see the Sending Logs link in my sig).
- CapellJun 06, 2018Aspirant
Thanks, that all seems very helpful. I'll see if I can manage all those actions. I am making full use of MyNetgear to support the ReadyCloud aspect of the NAS OS6 which is extremely useful.
Give a a day or so!
- SandsharkJun 06, 2018Sensei
What problem are you having with the Eaton? I have a 5P 1500 attached to my RN516 via USB and it works fine.
It simply won't connect. I select the Eaton UPS system offerrings in UPS options (either option: managed/unmanaged) and it always returns an error.
I can connect to a 4G UPS apparently (or in fact, one or two of the other options), the NAS sees the UPS, identifies the correct type and name, even serial number, but this is bogus. The UPS doesn't/cannot signal mains power failure to the NAS. So the NAS can see the UPS, but they're not linking properly.
Anyway, tomorrow, I might be able to re-connect with my support theme and get this resolved. This was all so simple with a ProPioneer!
I raised this thread simply because I had completely run out of options for contacting Netgear in the UK.
