Capell
Jun 06, 2018Aspirant
Failure of Netgear Technical Support
I am having problems connecting a NAS424 to an Eaton UPS 5P. I have raised this with Netgear support, and I have a running support case: 30039834. It's reached level 3. But now I can't reply to my ca...
Sandshark
Jun 06, 2018Sensei
What problem are you having with the Eaton? I have a 5P 1500 attached to my RN516 via USB and it works fine.
Capell
It simply won't connect. I select the Eaton UPS system offerrings in UPS options (either option: managed/unmanaged) and it always returns an error.
I can connect to a 4G UPS apparently (or in fact, one or two of the other options), the NAS sees the UPS, identifies the correct type and name, even serial number, but this is bogus. The UPS doesn't/cannot signal mains power failure to the NAS. So the NAS can see the UPS, but they're not linking properly.
Anyway, tomorrow, I might be able to re-connect with my support theme and get this resolved. This was all so simple with a ProPioneer!
I raised this thread simply because I had completely run out of options for contacting Netgear in the UK.
- mdgm-ntgrJun 06, 2018NETGEAR Employee Retired
If it's over USB the UPS should be automatically detected.
The dropdown is for connections over SNMP (which is of course over ethernet).
If you're using SNMP problems could relate to a faulty ethernet cable or a faulty port on a router/switch.- CapellJun 07, 2018Aspirant
It's an ethernet connection, NAS and UPS are on the same switch, both devices are visible from the DHCP router, both devices can see each other over the ethernet, but I cannot get a working SNMP connection. And all devices: router, NAS, and UPS are on latest firmware versions. I've tried the swapping cables malarky and that's not the problem.
- SandsharkJun 09, 2018Sensei
I assume you've also verified operation of the Network Card MS by separately logging into it. And using USB is not an option for some reason?
I've not tried an SNMP connection with a ReadyNAS and any UPS. But maybe somebody who has, even with a different brand, can be of more help.
