Capell
Jun 06, 2018Aspirant
Failure of Netgear Technical Support
I am having problems connecting a NAS424 to an Eaton UPS 5P. I have raised this with Netgear support, and I have a running support case: 30039834. It's reached level 3. But now I can't reply to my ca...
mdgm-ntgr
Jun 06, 2018NETGEAR Employee Retired
If it's over USB the UPS should be automatically detected.
The dropdown is for connections over SNMP (which is of course over ethernet).
If you're using SNMP problems could relate to a faulty ethernet cable or a faulty port on a router/switch.
Capell
Jun 07, 2018Aspirant
It's an ethernet connection, NAS and UPS are on the same switch, both devices are visible from the DHCP router, both devices can see each other over the ethernet, but I cannot get a working SNMP connection. And all devices: router, NAS, and UPS are on latest firmware versions. I've tried the swapping cables malarky and that's not the problem.
- SandsharkJun 09, 2018Sensei
I assume you've also verified operation of the Network Card MS by separately logging into it. And using USB is not an option for some reason?
I've not tried an SNMP connection with a ReadyNAS and any UPS. But maybe somebody who has, even with a different brand, can be of more help.
- mdgm-ntgrJul 17, 2018NETGEAR Employee Retired
Sveinolse it looks like you've posted in the wrong section unless you also have a NETGEAR ReadyNAS.
This section is for NETGEAR not for Arlo. You should open a post in the Arlo Community.
