HkJon
Aug 10, 2011Follower
False High Temp Reading - Ultra 2?
Hi,
I've just bought a ReadyNAS Ultra 2 and installed two WD 2TB "green" drives.
Everything seems to be functioning ok, but I have some strange temperature readings. When I hover over the temp indicator in RAIDiator, one drive consistently reads around 32C, whereas the other is around 70C. However, when hovering over the drive status, both drives read around 32C. Is this a known bug? Should I take the unit back to the shop for replacement?
(I'm running RAIDiator 4.2.17, using Safari in Mac OS X Lion)
1 Reply
- amac27Aspirantbase on my Ultra unit i see temp1: 45c/113F and temp2 32c/89f.
can you go the the health tab and check if you have a different reading on that page? Also what browser are you using?
