aris1234
May 16, 2016Aspirant
Fan 1 reported failed on NV+. Do I need a PWM 4-pin replacement fan?
Hello, I have an NV+ (older one - I believe it uses a Sparc). I'm getting notificatinons that Fan 1 has failed. It doesn't look like it has failed - as it is still spinning, but it does show 0 ...
BrianL2
May 16, 2016NETGEAR Employee Retired
Hi aris1234,
Welcome to the community!
Kindly look at this thread and hopefully it suffice.
Kind regards,
BrianL
NETGEAR Community Team
aris1234
Thanks for the response, but I can't really see the answer to my question anywhere. Lots of the links don't work either. I just want to know if I need a 3-pin fan or a 4 pin PWM chasis fan on an NV+.
thanks!
- mdgm-ntgrMay 16, 2016NETGEAR Employee Retired
Does this thread help?: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/NV-Fan/td-p/831711
- aris1234May 17, 2016Aspirant
Somewhat. From what I can see, it is a 3-pin, but nothing i've read explicitly confirms that. I've ordered one - i'll post the results when I swap it out.
- mdgm-ntgrMay 17, 2016NETGEAR Employee Retired
The NV+ (v1) is an evolutionary improvement over a product released over 10 years ago. So it is quite old hardware now.
With more recent ReadyNAS such as our current models we would use PWM.
