hawke84
Mar 03, 2015Tutor
Fan Control
Hi, I dont know if this has been requested, I cant find it anywhere.
I was wondering if its possible to create a fan speed control gui app. I understand there is already an init.d script to change fan speeds but i was after a more user friendly version. im surprised its not built into the web admin ability to have fan profiles..
im thinking like quiet, normal and turbo profiles at the simplest?
whats anyone else's thoughts?
- Equinox1GuideYes, this one has my attention too. It would be helpful to put the NAS in the right noise context.
- hawke84Tutorthanks, good idea. done :)
- RXLuminaryIt would be best if you will open a case with Netgear Support and raise your concern as feature request.
https://my.netgear.com/registration/login.aspx
