talksr
Jul 29, 2017Aspirant
Faulty ReadyNas Duo RND2120 v2 - Flashing Lights
Hi there, I am having an issue with my RND2120 v2. When I switch it on, Fan is on full speed Blue Power light is flashing At same time act, drive 1, drive 2 and light above backup button are all...
aks
Jul 29, 2017Virtuoso
You seem to have no disks instaled, but I think you must have at least one disk for the OS to be installed.
- talksrJul 29, 2017Aspirant
Thanks, ok if I insert a drive, the other lights go off, but the blue one continues to flash. With a drive inserted, the NAS does not show in raidar and I am completely unable to see it or ping it on network.
- aksJul 30, 2017Virtuoso
Was the inserted drive new/fresh without any partitions? It may be necessary to delete all partitions (in a PC) or force a factory default on the NAS. See these instructions.
