jimk1963
Jan 01, 2024Virtuoso
File copy from RN528 to RN424 - which method is fastest?
Loaded RN424 with new drives, everything is resynced and ready to be loaded up. Need to copy 10TB from RN528 to RN424. Limited by RN424 1GbE link. Observing an max of about 100MB/s over Windows 11 using Windows Explorer, close to the link capability.
Sometimes Win 11 Explorer file copy slows to a crawl, mainly dependent on file size. I’ve read that Windows file copy is inherently slow and shouldn’t be used for large transfers. What’s a better/faster method? I’m not necessarily in any hurry, but if I can shorten the process then I’d like to know how. There are programs out there like FastCopy, et al,… wondering if these are really any faster. Also wondering whether running ReadyNAS backup on the target NAS using RSYNC would be faster.
An rsync backup job could be faster, since it isn't piping all the data from RN528->PC, and then PC->RN524. More importantly, it would be more robust (less likely to miss something).
FWIW, I always use rsync for large NAS->NAS transfers. I set up rsync backup jobs for each share. I start with the smallest share (just to confirm that I didn't accidentally make a mistake in the settings).
- jimk1963Virtuoso
Thanks StephenB .
So the Rsync setup - struggling... again:
- Main NAS is 192.168.1.80, Backup NAS is 192.168.1.82
- Creating a new backup job from the Backup NAS GUI per our earlier chats
- First (left-hand side), choose "Remote" (correct?)... otherwise, when I choose "Local", I only see the Backup NAS folders
- Choose "remote: Rsync Server"
- Host: type in the Main NAS IP (xxx.xxx.x.80) per our earlier chat (instead of the NAS name) - is this correct? i.e., the Main NAS is the host?
- Port 873 is auto-populated
- Share: When I click "Browse" I can only see the Main NAS "Pictures" share - why? Cannot see "Documents" or other shares on the Main NAS. The "Pictures" share is mapped in Windows (X:), so do I have to map every share to a drive letter for it to be visible in this backup tool? Doesn't sound right. When I manually type in "Documents", the "Test Connection" returns an error. When I manually type in "Pictures", the "Test Connection" works. So I'm stuck. I don't know how to convince this archaic tool to add the share I want to backup.
This is what I meant earlier about not liking this tool. It's not intuitive at all. Previously, the only way I could get backups to work at all was by programming them from the Main NAS, where I could see the shares I wanted to backup.
- jimk1963Virtuoso
SMB3 is enabled on both NAS units as shown below ("Configure per share"). Not sure if this is relevant.
- bathanInitiate
I recommend using Third-Party File Copy Tools and as you mentioned (Fastcopy) ,also there are file copy tools like Gs Richcopy 360, Goodsync, or Teracopy that offer enhanced features and faster transfer speeds compared to the default Windows file copy. These tools often provide better control over the transfer process, including options for multi-threading, error handling, and network optimizations. You can try using one of these tools to see if it improves the transfer speed.
Another popular option (RSYNC) :
- Optimized for Network Transfers: As a command-line tool specifically designed for efficient network file synchronization, it can be significantly faster than Windows Explorer for large transfers.
- Benefits:
- Transfers only changed file portions, reducing network traffic.
- Handles interrupted transfers gracefully.
- Offers a high degree of control over the process.
Remember that even with these methods, the 1GbE link will ultimately limit your transfer rate. If you frequently deal with large data transfers and require faster speeds, consider upgrading to 10GbE networking for future-proofing.
- SandsharkSensei
Internally, backup jobs have numbers, not names. AFAIK, they are executed in numerical order. That order is generally the order in which you created them. But removing a job and replacing it with another will put the new one in the old slot.
FWIW, off-topic for this discussion, since this is about NAS->NAS file transfers and nothing to do with Windows.
I've used the old robocopy tool in Windows quite a bit - while perhaps not the fastest, it is extremely robust. Teracopy has a verification option (and of course a GUI), both of which are handy.
