lofstrom
May 19, 2012Aspirant
File system question
I have a Stora NAS which is dead, I would now like to replace it with a ReadyNAS Duo V2. How do I transfer my data? From what I understand these products use different file systems? /Stefan
mdgm-ntgr
May 21, 2012NETGEAR Employee Retired
lofstrom wrote: What file system is used by ReadyNAS Duo/NV+ V2?
Different RAID format is used. The ReadyNAS Duo/NV+ v2 uses the EXT4 filesystem. The only arrays that can be migrated to a Duo/NV+ v2 are ones created using another Duo/NV+ v2.
