joshuativis
Jun 26, 2020Aspirant
File Transfer Problems
About a week ago i started having problems transferring any files from a windows 10 computer to my readynas drive. All are hard wired in and below is what i have done to try and correct the issue.
Virus scan, malware scan, factory reset the router and modem. Restarted all devices several times. Also made sure all updates have been completed on all devices.
When i copy and paste a file i get Error 0x8007003B.
Any suggestions would be much appreciated.
You can't copy files in either direction? But you are seeing them in File Explorer?
- joshuativisAspirant
Thanks for you response. Amazingly when i sat down to work on the problem tonight it started working again.
