MrCyberdude
Jul 28, 2024Guide
Firmware 5.3 update with TLS support for Browser access ReadyNAS NV+ v2, RND4000v2
Netgear needs to supply a basic Firmware 5.3.x update with TLS support for Browser access to get past the error "SSL_ERROR_UNSUPPORTED_VERSION" . If the community has a fix then Netgear needs to make...
Jul 29, 2024Guru - Experienced User
Netgear won't. The NAS went end of life a long ago, and Netgear notificed users that 5.3.13 would be the last firmware update.
WhoCares_ created an add-on that adds TLS support:
MrCyberdude wrote:
I have found that K-Meleon browser got me into the admin screen in Windows11 when no other browsers would.
Firefox will also. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
Edge should work to, but you need to use legacy mode.
