swehjo
Apr 17, 2014Guide
First NV+ dies and now "SATA reset"
Hi there, A couple of days ago my Readynas just stopped working. Off-button didn't work so I had to disconnect the power. Came up again and I did a resync etc. All fine I thought. Today I got the err...
mdgm-ntgr
Apr 18, 2014NETGEAR Employee Retired
Probably one or more of your disks is bad. Can you check them using SeaTools?
