XrayDoc88's avatar
XrayDoc88
Apprentice
Dec 18, 2017
Folder Missing In ReadyCloud?
I have a folder that I copied to my NAS music folder named ".38 Special".  If I browse to that music folder on Windows 10 using "network" I can see the folder (although it is grayed), open it and pla...
  • dschwartzer's avatar
    Dec 18, 2017
    Yes the dot "." makes the folder a hidden folder.  If you can see the folder from your Windows computer, try renaming it without the dot and you should then see it.
ProSupport for Business
