Avinashkumar
Jan 27, 2022Follower
forgot router login user
Dear Team, Router is showing offline, We could not able to login as we forgot the user name and password.
Jan 27, 2022Guru - Experienced User
If you're talking router, theres a password recover feature. Problem is that if you didn't set it up or dont' know the answers, then its just loop and you can't get back in. If thats the case, you'd need to factory reset to get back in.
