Magmo
Mar 03, 2014Aspirant
format disks..
Hi
I want to format/delete al files thats being stored on the ReadyNAS Ultra 4 Plus, from where in the admin interface can I do that?
- vandermerweMasterGo to raidiator.
Select System, update.
Select factory default.
Perhaps before you do this you could upgrade to the latest firmware (4.2.26).
This will wipe all your data and reset the device to factory settings - your network settings will be reset so you'll need a dhcp server on or you can reach the NAS through raidar.
You may also want to backup your configuration, then restore it after the reset. This is also in the system menu. - MagmoAspirantThanks that worked perfect!
