christianfriish
Jan 15, 2013Aspirant
Format hard drive from Readynas DUO so it can be used as USB
Hi. I have a problem that I cannot solve. Recently I wanted to use my 2 x 1 TB Seagate hard drives from my Readynas DUO as USB-hard drives. I found the right enclosure for them and connected them t...
Jan 19, 2013Guru - Experienced User
You format the hard drives on the PC via disk management (right-click on computer, and select "manage").
