  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Very weird. I've tried it at a few locations and I can see it fine at both.
  • ah.. maybe its because i use the old forumtheme, and not that new one :)
    mdgm-ntgr
    That could be it. I'm using prosilver, not the old subsilver2. I stayed on subsilver2 for a while, but eventually decided to switch. Although the different look takes some getting used to, it has some nice features e.g. limits space on the screen taken up by stuff in code tags, so if you don't want to read it all you can easily scroll past it.
  • I switched to subsilver2 and the text is in the center of the top panel without NAS images, switched back to Prosilver and the logo is in the upper left.
ProSupport for Business
