lennart1
Jul 30, 2013Aspirant
From RND2000 to newer model, migrating disks?
How can i migrating the data on disks when u go from a RND2000 to a newer model? Which model should i take? The disks are in a X-RAID2 config.
mdgm-ntgr
Jul 30, 2013NETGEAR Employee Retired
None of the Duos are x86.
The v2 (which presumably you have if you are using X-RAID2) is ARM.
Newer models use a different filesystem. So you should purchase new disks and transfer your data across your network e.g. using a backup job.
