cathcam
Apr 09, 2019Guide
Frontview not accessible
I have 2x ReadyNas NVX running the latest software. They've both been installed for a very longtime. One is the primary, accessible via Windows 10 shares, and I have enabled SSH. The primary also runs as a logitech music server(LMS), installed via frontview.
The other is just a backup that does an rsync backup of the media share.
I couldn't get the latest version of the LMS running and was doing some debugging with Michael from Logitech via SSH. I tried starting LMS via SSH and it failed, once with a segment failure, and the second time with a perl compilation error.
I went back to reload a working LMS level via frontview, and it is no longer accessible, even after a reboot. Chrome reports
This site can’t be reached 192.168.0.2 refused to connect.
ERR_CONNECTION_REFUSED
The shares are still accessible, as is SSH. I tried following the instructions in https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/No-access-to-Frontview-Duo-V1-running-4-1-6/td-p/1693316
and Apache started, but still not accessible.
I'm guessing when we tried to run the LMS from the SSH shell something got overwritten, or a config file changed.
Apart from doing an OS Restore and resetting the primary readynas does anyone else have any ideas on how to recover this?
- cathcamGuide
In case anyone is intereste, I've attached the syslog from the time the defective LMS 7.9.2 was installed, followed by a shutdown and sometime after that we ran the LMS via SSH and thats where I am now, no frontview. Only able to retrieve logs via SSH.
ideas or help would be really helped. I've got 4.2Tb of data behind this server and even with a backup it will take a long time to recover.
- cathcamGuide
In the end I did a firmware reload from the boot menu. I backed up the data from the NAS first, but that wasn't needed.
Better safe than sorry.
