Blues11
Jan 26, 2015Luminary
Frustrating, but in the scheme of things...
I have finally decided to bite the bullet and purchase a new NAS. I purchased a ReadyNAS Pro Business 5+ years ago and it's still running, although the fans start spinning at over 2K rpm more often th...
Jan 27, 2015Guru - Experienced User
You can certainly use frontview's backup to back up RN516 share to your pro.
If there turn out to be issues with replicate, you can also install OS6 on the pro. That's not supported by netgear, but there's a lot of information here on how to do it.
If you are willing to tinker, you can also replace the fan in the pro. Cleaning it might also help.
