Xophile's avatar
Xophile
[FSP Group] [EP 450] - Compatible with Ultra 4?
Hi!
Does anyone know if I can expect any problems with a simple UPS from FSP? EP450 is interesting considering the price but it's not mentioned anywhere.
Thanks!
  • Hello,
    I have searched and do not see any entries about the UPS. The forums is the best way to find out and since there are no entries regarding that UPS it's hard to say. You can always test and let us know, I would recommend of course if you are purchasing specifically for the ReadyNAS that you know the return policy from the vendor, in case it does not work you can return it.
    If you do purchase one to test please let us know the results.
    Support Resources
    Forums:
    Prosafe: http://forum1.netgear.com
    ReadyNAS: http://www.readynas.com/forum
    Prosecure: http://prosecure.netgear.com/community/forum.php
    Contact support or register a device
    1-888-NETGEAR (638 - 4327) Option 4 for technical support
    http://my.netgear.com
    Knowledge base
    http://support.netgear.com
  • Thanks for you reply!
    I just ordered a EP650 and the retailer promised me a free return. I'll let you (and the forums) know as soon as I've tried the UPS with my Ultra 4.
    /Matt
  • Hello again!
    I was unable to purchase the EP450 becasue it was out of stock. I did get a EP650 (almost the same but better battery as far as I could tell).
    My ReadyNAS Ultra 4 did not see the UPS at all. I've tried multiple restarts, different USB-ports, with/without my USB-printer attached etc.
    I guess it's simply not compatible and I'll have to look at an APC instead.
    Can somebody please update the compatibility list?
    Thanks!
ProSupport for Business
