atz6975
Dec 10, 2007Guide
FTP in R4: no resume with disk spin down
Hello there, I experienced something quite annoying. R4 (original) Smart FTP client uploading from XPSP2 to the NV + File is one Zip of 145 MB Spin down of disks at 45 min inactivity The fil...
WillisFabros
Oct 19, 2011Aspirant
I go to the local update page, choose the image file and begin the update process. RAIDar shows that it is updating for about 5 minutes then it disappears from RAIDar never to be seen again. All I get is blinking blue power light on the 1100. Power cycle does nothing. No network activity and no other lights. I was forced to take out the usb flash disk and reflash it using rawrite32.exe. First I reflashed with R4. 1100 still will not boot up. I had to flash R3 back on there. Once rebooted I could not access the admin console. I had to hold down power button for 5 seconds at boot up to reinstall image onto 1100. Finally seems like it was back to normal. I decieded to try the update proccess again. Same exact issue!! I already sent in log files.
