leew87
Mar 20, 2019Aspirant
FTPS setup
hi i am trying to setup FTPS on my READYNAS 104
it works find with FTP but can not seem to get FTPS working
i have forwarded port 990 and passive port range on 50001 - 50030 to the NAS ...
Mar 25, 2019Guru - Experienced User
i have forwarded port 990 and passive port range on 50001 - 50030 to the NAS IP address what am i misisng
You need to use explicit SSL signaling in the client ("
990 is the default port for implicit SSL signaling, so you'd either need to specify it in the client, or just use port 21.
