mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
- mdgm-ntgrNETGEAR Employee RetiredHi nikoniko, I just had a look at your logs.
Can you try disabling the anti-virus service and see if you still have issues?- nikonikoTutor
Can you try disabling the anti-virus service and see if you still have issues?HI mdgm
I disabled the antivirus and now the NAS seems to be alive.
Thank you very much for your help.
I also had an automatic update to 6.2.5 recently and it seems to also be fine.
best regards
Nikolas
- nikonikoTutormdgm thank you for responding.
I have sent the email with the logs but I haven't receive any response so I do not know what happened to them - mdgm-ntgrNETGEAR Employee Retirednikoniko can you try 6.2.5-RC1?: http://www.readynas.com/forum/viewtopic.php?f=154&t=78866
If you send me your logs (see the Sending Logs link in my sig) I can confirm if you have an issue likely addressed by 6.2.5 - nikonikoTutor
BubbaMike wrote: Since upgrading to 6.2.4 my RN104 crashes/locks up/stops responding/etc almost every single day. Pulling the power plug is the only option.
..the NAS will almost always fail when I am not around to reset it and then it causes problems. I just want a stable firmware running...is that too much to ask? LOL
Hello
I am experiencing the same problem after upgrading to 6.2.4.
The upgrade was done automatically.
The NAS dies a few minutes after power on and the only solution is to remove the power.
The hardware is relative new. I have it for a few months but has only been online for a few hours as most of the features are not working yet (e.g. Syncing with ReadyCloud etc)
Does anyone know if there is a fix coming soon? - btaroliProdigy
Jophus wrote: It is a testament to Netgear for unofficially supporting legacy devices.
No. Netgear has officially decided NOT to do that. This is a testament to those who have acted against Netgear's business decision to instead do the right thing for customers. But beware because if something goes sideways and you need to call Netgear support, it's likely they won't.- JophusLuminary
No. Netgear has officially decided NOT to do that. This is a testament to those who have acted against Netgear's business decision to instead do the right thing for customers. But beware because if something goes sideways and you need to call Netgear support, it's likely they won't.I definitely appreciate your view! Personally, by fostering a vibrant and engaged community and by enabling those exeriences to be shared via this sanctioned Netgear forum, I feel Netgear walk the line of:
- Business, turnover, upgrade culture, forced obselesence etc, and
- Enabling and supporting those who are willing to help themselves.
My experience with these forums and my Ultra 6 led me to double-down and buy a 102 to back-up my Legacy Ultra 6 (on 6.2.4).
My suggestions for the RN102 are:
- The status page on the 102 is missing a lot of information (compared to the Ultra 6), like network throughput, IO, temperature etc and history - no pretty graphs or even just some numbers. Is there a view to include some diagnostic/snapshot information on the RN102?
- On both the 102 and Ultra 6 it would be great to have a "force compression" on shares and also an option to recompress files already on the NAS.
- This could ideally come with a warning that throughput/performance would be impacted etc. BTFRS will only compress a file if the first few blocks of a file are compressible. Forcing compression will do just that for all files, irrespective of the first few blocks' compressibility. This would be perfect where my 102 (which maxes out at 41MB/s using Copy on Write/Compression - faster than USB2 on the Ultra 6) is a back-up only box and write speed is not the primary concern.
The 100 series does not have the resources to do those graphs. If you need that information you should consider a business class ReadyNAS.
In a future firmware release you will be able to force compression on a directory from the backend.
I also connect this way, and this problem has been therefore a couple of releases now. It would be nice to get it fixed.Jophus wrote: - Small issue, but landing page app-installed icons don't work when used on non-standard port (I have a high range port >40000 to connect to secure web interface. Inspecting the elements which make up the links to the icons I see: <img width="64" height="64" src="https://ipaddresshidden/apps/logo/lms.png" id="ext-gen431"> (ip address hidden) with no reference to the port number needed to connect... should this not be ipaddresshidden:40000 or similar (in my instance).
- JophusLuminaryHey All.
I recently upgraded my legacy device from 4.2.27 to 6.2.4 - I won't provide feedback on that process within this forum. Needless to say, 6.2.4 effectively reinvented the Ultra 6. Much easier and better to use. It is a testament to Netgear for unofficially supporting legacy devices.
The following is a list of things I have noted from my experience with the new version:.- Mobile device web view is horrendous. Navigating on a phone is horrible with poor scaling and issues with frames. This should be improved.
- Dropbox backup-only is a bit disappointing. I have 3 PCs, a laptop and 2 mobile devices which would benefit for being LAN sync'd, rather than the Readynas being a one-way only "send backup to Dropbox" device. RNXtras paid addon holds promise, except it is broken on install with "bad config" and won't spawn a HTTP config page with missing URL (I'll seek support from him)
Thanks! - Mobile device web view is horrendous. Navigating on a phone is horrible with poor scaling and issues with frames. This should be improved.
- mdgm-ntgrNETGEAR Employee Retiredjefft please contact support.
- jefft1AspirantI was on 6.1.8 which was extremely stable for many months; I was doing some server room housekeeping and had to power down the 3220 so when I brought it back up, I foolishly thought it'd be a good opportunity to upgrade to a more recent firmware (6.2.4).
As a result, I'm stuck with massive Windows Active Directory (2008) authentication errors with basically no workstations being able to access the CIFS share. I've tried re-adding the unit to AD with no luck and /var/log/samba spits out errors like:
[2015/07/07 21:39:06.878215, 1] ../source3/auth/user_krb5.c:164(get_user_from_kerberos_info)
Username XXXX\nicholeh is invalid on this system (where XXXX = my domain name)
Any suggestions on how to quickly get this resolved??? - stoney066AspirantI have a 316, ever since upgrading to 6.2.4 the lights on my unit stay on (not the lcd panel, just the purple netgear logo and the circle w/arrows). Rebooting the unit turns the lights off for a while but eventually they come back on all the time.
Other than that 6.2.4 has been great, finally able to stream music from itunes ;)
