HERBIEO
Oct 16, 2012Aspirant
genie app store shows incorrect device case # 19675450
Decided to take the plunge and create a new account with a different email as the one the device was registered with would not allow to log in, so after creating account logged in from dashboard and a...
Skywarp
Oct 17, 2012Tutor
Can you PM me the serial number of your ReadyNAS so I can have a look in the system here?
They have the same architecture and most, if not all, apps for the one should run on the other.
edit: got the PM, created case # 19675450 to check
edit2: escalating the case, seems to be just with this serial/account.
