Foe_of_Good
Jul 10, 2017Aspirant
Going from NV+ to RN104 - Can I still access my data?
So, I've had an NV+ that suddenly went BOOM. Something smelled burned and it never awoke again. I allready have a RN104 that I wanted to test the disks in, and I have also bought another 104, but wh...
Foe_of_Good
Jul 11, 2017Aspirant
Ah, yes, there is that...
Ok, so do you think I could use the PSU from the RNDU4000 to power up my NV+ again?
Or are those two PSU's miles apart as well?
Jul 11, 2017Guru - Experienced User
The pinout on the NV+ connector is nonstandard, so there's a change you'd have to make there. If you don't try to put the PSU into the NV+ chassis, you can do that change on an extender cable (leaving the PSU wiring intact). Hopefully Sandshark will chime in on this, since he's very knowledgable on PSU replacement.
- SandsharkJul 11, 2017Sensei
Yes, the power supplies are interchangeable, and not really very hard to swap. It will get your system back up if that's all that's wrong; and if I were betting, that would be the best bet. If the power supply took something with it when it died, you're in trouble. If something else took the supply out, it's worse (you likely fry the other supply).
