funglenn
Nov 13, 2017Luminary
Hard drive compatibility and vertical expansion
I have a readynas 516 running 6.6.0 and i tried to replace a WD Black Enterprise 1 TB drive with a WD green 2 TB drive. i knew it was NOT on the compatabiliy listing and was not fully surprised it d...
Sandshark
Nov 13, 2017Sensei
What sizes are your other drives? There are expansion combinations that don't work. The other possibility is that the drive has too many bad sectors above the 1TB mark. Did you do both read and write surface tests, or just read?
- Sep 06, 2016Retired_Member
