borisw37
Jul 23, 2013Aspirant
Hard drive failure issue... Case # 21655682
I have ReadyNAS NV+ v2. Since the start I had four 2TB hard drives and all was good. Recently the system indicated HDD1 failure. I removed & reinstalled the same drive. System rebuilt the data. Few d...
mdgm-ntgr
Jul 23, 2013NETGEAR Employee Retired
Can you hook up the drives to an internal SATA port in your PC? Check the SeaGate drive using SeaTools and the Western Digital drive using WD LifeGuard Diagnostics. Both of these can be found on the Ultimate Boot CD.
