chopin70
Feb 03, 2018Virtuoso
Harddisk with Power Disable Pin (HGST)
Hi, In this page, for part selector of HGST disks: https://www.hgst.com/products/hard-drives/ultrastar-he12 They talk about SATA 3.3 specifications and the new "Power Disable Pin" feature If n...
Frank888
Feb 04, 2018NETGEAR Expert
We didn't use Pin 3 on the connector of backplane (No Connection) on all desktop models.
Since Pin 3 is no connection, that is this pin is floating, no guarantee the power level.
If you use the HDD with PWDIS, it may or maynot spin up.
Highly recommand to use the HDD which is not support PWDIS feature.
Sandshark
Feb 04, 2018Sensei
Frank888, do you have access to a SATA 3.3 spec? Every article I see says that all that is necessary is that pin 3 not be connected to anything above 2.1V unless it's the actual PWDIS discrete. The implication is there is a pull-down on the signal, so floating the other side is just fine. In fact, HGST and others recommend just using a MOLEX 4-pin to SATA power adapter since the MOLEX has only +5 and +12V, leaving pins 1-3 floating. Personally, I'd just cut the 3.3V wire where it's possible (which should be all cases where the MOLEX adapter is also an option)..
But while it's still an option, just getting the drive version without that feature is the best move.
- chopin70Feb 05, 2018VirtuosoIt seems all 12 tb from hgst have the feature
- Frank888Feb 05, 2018NETGEAR Expert
If you read from the P/N selector carefully, the upper half parts are HDD without this feature, the lower half parts are HDD with PWDIS feature.
- chopin70Feb 06, 2018VirtuosoYou're right. I did not notice that part numbers are different for the same model numbers
