plingis30000
Aug 27, 2011Aspirant
Hardware - the same in Duo as in NV?
Hi! I´m having this problem: viewtopic.php?f=7&t=56262 From the support in Sweden, I got the answer that it will may cost the same to repair the Duo chassi as a new chassi for a Duo or a NV+. I also...
dbott67
Aug 27, 2011Guide
Provided the data volume/array is still functional, yes, you can migrate from a Duo to another Duo or NV+. The Duo and NV+ both use the same basic hardware.
http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
