plingis30000
Aug 27, 2011Aspirant
Hardware - the same in Duo as in NV?
Hi! I´m having this problem: viewtopic.php?f=7&t=56262 From the support in Sweden, I got the answer that it will may cost the same to repair the Duo chassi as a new chassi for a Duo or a NV+. I also...
ReadySECURE
Aug 27, 2011Apprentice
Also remember if you purchase a NV+, that because the Duo only had two drives you will need to initialize with just those disks and in the corresponding place as on the Duo.
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources -
Forums:
Knowledge base
