joe_wht
Mar 10, 2016Luminary
Have a Hidden Drive & Open Drive ??
I use my MacBook ethernet wired 99% of the time ( 1TB SSD + second 1TB SSD) I use my Windows Desktop PC(3TB 2nd HD) 1% of the time OLD OLD External HD ( 2x 500gb) for archive. Every few months I ...
joe_wht
I see the NETGEAR ReadyNAS 316 is $599
and the NETGEAR ReadyNAS 214 is $486
.. What is the difference ??
I can only find specs for the 200 model.
what makes the 300's $110 more ?
the Ram seems to be the same.
Kardano
316 is 6 bay (6 HDD, CPU is x86, 5 years warranty, and if i'm correct there is lifetime chat support) model for business,
214 is 4 bay (4 HDD, CPU is ARM, 3 years warranty) model for home.
- StephenBMar 11, 2016Guru - Experienced User
Correct. As far as support goes, the RN214 only has 90 day free installation support - anything beyond that is paid.
There is one feature inversion - the lower-end RN214's ARM supports real-time 1080p transcoding with plex, but the RN316 does not.
The older RN20x is dual-core (compared to the quad-core RN214), and does not support real-time transcoding.
RN214 specs are here: http://www.netgear.com/home/products/connected-storage/RN214.aspx
