joe_wht
Mar 10, 2016Luminary
Have a Hidden Drive & Open Drive ??
I use my MacBook ethernet wired 99% of the time ( 1TB SSD + second 1TB SSD) I use my Windows Desktop PC(3TB 2nd HD) 1% of the time OLD OLD External HD ( 2x 500gb) for archive. Every few months I ...
joe_wht
Mar 11, 2016Luminary
Thank you guys !!
I just ordered the 214.
I went ahead and got the 4bay
I'm gonna move my ( never use) Desktop 3TB to the 214, I ordered a 2nd 3TB (for a Rsync clone-- I think)
I WAS thinking about just trashing the Two 300gb & only getting the 212- 2bay, but decided to fill the 2 extra slots
and use it for ~Something~..
Any idea on how I can keep a Hidden Drive or Folder for my financial docs ?
I want it hidden but easy access for myself.
But I want everything else available for family.
Years & Years ago in windows (i'm now a mac person) I could hide a drive (never shown in expolorer nor network)
and symply type the drive letter in the address bar and it would appear.
But of course they changed in Windows.. and I've never been able to do that in Mac.
Mar 11, 2016Guru - Experienced User
The second drive allows the NAS to create a RAID array (it has nothing to do with rsync). RAID will allow you to replace a disk (or expand the capacity of the volume) while keeping the data available/on-line. It is not a substitute for backup - so you should sort out a backup plan for the NAS. USB backup is popular and inexpensive. I also suggest getting a UPS at some point. Unexpected power loss can create problems (including file system corruption), so it is good to avoid it.
On drives...
Some drives are not well suited for NAS (or RAID). There is a hardware compatibility list here: http://kb.netgear.com/app/answers/detail/a_id/20641/~/readynas-hard-disk-compatibility-list You can also search this forum on the particular models you want to use.
Netgear will usually deny support if you use a drive that is not on their HCL. Also, I don't recommend Seagate DM drives or green drives for your NAS. I do recommend NAS-purposed drives (WDC "Red", "Red Pro"; Seagate VN). These have better warranties than desktop drives, are designed for NAS use, and are about the same price as desktop drives. Enterprise drives of course can also be used (but are more expensive).
On hidden folders...
On the NAS, you'll have one volume (which you can think of as a virtual disk). You then create "shares" on that volume which you access from your Mac with finder.
There is an option in the NAS web ui to make a share hidden. "hidden" is not the same as "inaccessible" - but you can also limit access using the Web UI if you wish.
