PeteCress
May 13, 2017Apprentice
Have RAID5, 5TB populated out of 10 available: any hope of increasing to RAID6 without reloading?
Somehow I messed up in my RAID level specification. Now, after two days of loading, my new RN316 with 4-4tb drives has 5 tb of data on it but the RAID level is only 5 and I wanted 6. Projecte...
PeteCress
I cannot find any way to edit my OP, so here goes....
I think I answered my own question and the answer is "No, a RAID5 array cannot be upgraded to RAID6 without wiping the data and then reloading after the upgrade.".
But that begs another question: Do I want RAID6 or X-RAID2?
The desired bottom line is that the box can have two (2) drives fail and still not lose any data.
Sandshark
May 13, 2017Sensei
If you are going to be wiping things out and stating over, you may want to consider moving to OS6 on your Ultra6. It gets rid of a lot of the volume limitations, allows you to move between XRAID and FlexRAID (as long as there is only one data volume), and is based on a current Debian distro.
- jak0lantashMay 14, 2017Mentor
Don't be confused about the "2" in X-RAID2, it's just the name of the feature as shown on your device. It was called X-RAID on RAIDiator 4.1, then X-RAID2 on RAIDiator 4.2, and X-RAID again on ReadyNAS OS6.
To use RAID6 on your Ultra6, you need to use Flex-RAID (For OS6: disable X-RAID after initial setup, recreate the volume as desired. For RAIDiator 4.2: use RAIDar during initial setup.).
- PeteCressMay 14, 2017Apprentice
My bad: I muddied the waters device-wise.
I do have an Ultra-6, but the question is about my new RN316.
The plan long-term is to put OS-6 on the ultra, but here-and-now I want to get the 316 up and running with 2-drive redundancy.
Can anybody:
- Confirm that I really do have to wipe the current RAID5 array before making the 316 2-drive-redundant?
- Give the exact, precise, letter-for-letter name of what I am looking for 2-drive-redundancy-wise? .... So far, it is sounding like "RAID6".
Using the GUI, you won't be able to modify your RAID5 array into a RAID6 array.
From the back-end, there is a solution:
- disable X-RAID.
- insert a 5th drive.
- use mdadm to reshape your RAID array from 4-disks RAID5 to 5-disks RAID6.
But I wouldn't advise doing that unless you're confident with SSH and mdadm.
So I do advise you to wipe the array and recreate as RAID6 for dual redundancy.
