davidenco
Mar 25, 2015Aspirant
Have to reboot ReadyNAS to use USB hard disk?
I have connected a Tandberg QuikStor RDX USB3+ hard disk enclosure with 2TB hard disk to my ReadyNAS Duo v2. In order for the RDX to appear as a USB share, I have to reboot the ReadyNAS first. When...
RX
Mar 25, 2015Luminary
@davidenco:
Did you connect your Tandberg QuikStor RDX USB3+ hard disk enclosure with 2TB hard disk to either of the USB 3.0 ports of your Duov2 which is located at the rear panel?
Does same problem occurs if you connect it to the USB2.0 port at the front panel?
Just to further isolate the problem, do you have another external USB drive and check if same problem will occur whether its connected to either USB 2.0 or 3.0 ports of your NAS?
