davidenco
Mar 25, 2015Aspirant
Have to reboot ReadyNAS to use USB hard disk?
I have connected a Tandberg QuikStor RDX USB3+ hard disk enclosure with 2TB hard disk to my ReadyNAS Duo v2. In order for the RDX to appear as a USB share, I have to reboot the ReadyNAS first. When...
davidenco
Disk is formatted to NTFS.
The RDX behaves in the same way whether it's connected to the rear ports or the front port.
Connecting a USB SD card to the front port works first time without a reboot.
Will the RDX work with a newer model, perhaps one which uses the latest OS/Kernel?
